Flyingshark
Thanks! I was surprised it turned out this well, since this is my first scratch build. I think the cockpit really completes it.Awesome looking build!
Could you post a link to the plans for the cockpit maybe?Thanks! I was surprised it turned out this well, since this is my first scratch build. I think the cockpit really completes it.
I linked the thread where someone else designed it earlier. I don't think I should directly link their work, though.Could you post a link to the plans for the cockpit maybe?
I missed the link before somehow - thanks!I linked the thread where someone else designed it earlier. I don't think I should directly link their work, though.
Here's the thread again: Plans are at the bottom of the first post.
https://forum.flitetest.com/index.php?threads/ft-spitfire-canopy.6136/
You right click to save the image and then export it from something like Preview as a PDF. I just printed the pdf without resizing it. Worked great!
I've flown a bunch on simulators, but in real life my experience consists of a few flights with an FT Long-EZ, a few with a Tidewater (before that crashed and the ESC caught fire) and a 2ch glider I built.Just some suggestions which you may or may not already thought of (and I have no idea how experienced a pilot you are so sorry if this too obvious). Try to have an experienced helper hand launch it for you (actually an inexperienced one may be better than doing it yourself as its not easy to hold). It flys pretty fast at full throttle so once it gets moving don't forget to throttle back. You might dial down those high rates. About the ailerons....On up aileron, If the bottom of the aileron is about two mm(s) above the wing that will give you lazy large circles.
Nice!I flew the Spitfire today!!!
It took off around 60-80% throttle (there was a minor headwind helping it) and I got a short flight in. It ended when I forgot how to turn because I was so excited and it dropped most of the way to the ground, so I just let it go in. Seemed like a pretty soft controlled crash, but the prop was broken.No more flying today.
Anyway, apologies about the lack of video; I had my dad hand launch it so he wasn't able to video it. For the next flight I'll try to throw it myself and get him to video the flight. Hopefully I can manage to not break my other prop!
Try one of the APC 9x6 thin electric props. They are really durable!I flew the Spitfire today!!!
@The Hangar,Try one of the APC 9x6 thin electric props. They are really durable!
https://store.flitetest.com/apc-9x6-thin-electric-propeller-apc09060e/p17930
I think I need a bigger field to really be able to explore what the Spit can do. I had a moment where it's turning circle on low rates was slightly wider than the field, so it flew by 30 feet over my head before I got it back into the box I wanted to fly in. Also, I kept needing to do very steep turns to get it going where I wanted it to go. I think I might try to improve my flying skills on smaller planes for a little while, maybe even until my local flying club opens up and I can use their field. I had the throttle at 50% for most if not all of the flight. I was using the 10x4.5 props that came with the power pack, but those two are all gone, so I think I'll order a lot of those 9x6s.You made a really clean build for your first, and you couldn't have chosen a better warbird to fly. To learn from as your first plane it is a little fast but you can slow it down nice. It has huge under cambered wingtips and with the dihedral it is super stable at lower speeds.
That being said I would suggest trying to keep the throttle in the 50-60% range on the previously suggested 9x6 prop. On 3s this prop does this plane so much justice on the C pack radial. If you already have it trimmed out you should be able to do circuits and figure 8's all day long.
I would also suggest setting your expo higher on high rates to help it feel like low rates when you switch over, just that it has more throw. Example low rates set to 30-35% at say 65% throw, 45-50% expo on high rates at 100% throw. This way the low end of the stick travel on high rates feels just like your low rates. If that makes sense.
I do have a thread on the stuff i did to my Spit when I built it over a year ago. I loved that plane. I built it and was novice enough that it scared me to fly it. 50% of the fear was i didn't know what the plane was going to do in the air, mostly stemmed from repeated failed attempts at teaching myself to fly. The other 50% was that i spent a decent amount of time on it and didn't want to ruin it yet. I got down to the point where i just had to force myself to toss it up, and it surprised the hell out of me. Flew like it was born to be at my control, was effortless to maneuver or even give it room while you decide what you want to do with it. Every time i see someone build one i want to build another. It has a bit of nostalgia for me
Not to sure but it sounds like you are a bank and yank kinda guy, just like me, i am left thumb dumb. And lazy at times. I sometimes will mix a little rudder into my aileron inputs to help facilitate the turns to be more coordinated, maybe the DX6e will mix that, maybe not. But you could try some rudder input to get the tail around with out having to roll it over to get the turn.I think I need a bigger field to really be able to explore what the Spit can do. I had a moment where it's turning circle on low rates was slightly wider than the field, so it flew by 30 feet over my head before I got it back into the box I wanted to fly in. Also, I kept needing to do very steep turns to get it going where I wanted it to go. I think I might try to improve my flying skills on smaller planes for a little while, maybe even until my local flying club opens up and I can use their field. I had the throttle at 50% for most if not all of the flight. I was using the 10x4.5 props that came with the power pack, but those two are all gone, so I think I'll order a lot of those 9x6s.
That thing about expo does make sense. I accidentally maidened it on high rates, and overcontrolled it (resulting in broken prop #1), but then when I flew it on low rates, I felt like I needed just a little bit more control to get the turns I needed.
Yeah. I briefly flew the FT LongEZ, so I got into the habit of turning with the aileron and forgetting about the rudder. If I had more time in the air, which hopefully I will in the future, I could probably start remembering to vary the throttle and use the rudder a little to help the turns along.Not to sure but it sounds like you are a bank and yank kinda guy, just like me, i am left thumb dumb. And lazy at times. I sometimes will mix a little rudder into my aileron inputs to help facilitate the turns to be more coordinated, maybe the DX6e will mix that, maybe not. But you could try some rudder input to get the tail around with out having to roll it over to get the turn.
I like to fly a lot of warbirds and usually faster stuff so the bank and yank thing is just habit like breathing. Tip stalls don't happen to much when you are carrying some decent speed. But i am trying to slow things down and built the Easy AF Edge for 3D practice, try to do some hovering and harriers in the back yard right. Here is how I flew the maiden...Yeah. I briefly flew the FT LongEZ, so I got into the habit of turning with the aileron and forgetting about the rudder. If I had more time in the air, which hopefully I will in the future, I could probably start remembering to vary the throttle and use the rudder a little to help the turns along.
I'll look into trying to mix the rudder in. I think that is possible with the DX6e, but it might take a little while to figure out.
Flying my 3 channel Baby Hornet might also help me remember the rudder, since it doesn't have ailerons. And the Mini Speedster. And my UMX Whipit. Wow! I only just realized that every plane in the "on the workbench" part of my signature is 2 or 3 channels, with no ailerons!
