TooJung2Die
Changes needed, advice appreciated.
This is my first attempt at airplane design. That's why I started with a proven airplane. It has become apparent that designs that are good for free flight don't always work well with RC without modification. I got it up and flew it around a bit. Getting it back down safely was more luck than skill. It flies like it is excessively tail heavy. It wants to point the nose towards the sky and getting it level wasn't easy. Keeping that attitude was impossible.
The CG was at the front of the wing spar. The original assembly instructions for the balsa Ranger show the CG further rear than that. If it needs more weight in the nose then more weight it is.
The wing's incidence angle is less than the original plans. It is currently 2 degrees relative to the horizontal stabilizer. Should I make it zero degrees like the Tiny Trainer? I guess I can try shimming the trailing edge of the wing to see.
I had the motor set to 4 degrees right angle thrust. No down thrust. Should I angle the motor down as well as right?
The vertical stabilizer and rudder probably need to be bigger. Rudder response was like it was on a delay. Nothing, nothing, then it began to turn. Could be because it's tail heavy too?
I'm building the third fuselage. This one has a vertical stabilizer 5" tall instead of 3.75". I think the taller v-stab even looks better. The motor is installed with 4 degrees right and down thrust.
I'm going to use the old fuselage and wing as a chuck glider to experiment with the CG and incidence angle. I hoping if I can get those worked out then all I should have to figure out is the motor thrust angle?
Too gusty to fly even a chuck glider so I'm working in the shop.
Jon
Jon
