If I am running ESCs with a heatsink I can get away with putting the ESCs in the frame. When I am running ESCs without a heatsink or where I will push enough power through them that the heatsink must have air, I put the ESCS on the boom under the fat part of the prop so the propwash will cool the ESCs.
I always cover carbon fiber with a non-conductive material (heat shrink) that is ONLY to isolate the CF from electronics. Each boom on this copter will get heat shrink just to cover part of the boom where the ESC will sit. If I individually heat shrink the ESCs, I use two sided tape between the two layers of heat shrink and a zip tie to keep it from shifting. If I use heat shrink to cover both the boom and the ESC at the same time, the heat shrink holds the ESC on the boom and I use a zip tie to keep it from sliding around.
I found in the past that two sided tape under a KISS ESC without a layer of heat shrink between the tape and the ESC causes the tape to melt and get into the ESC and the ESC simply sits on the boom anyway once the tape melts away.
If the ESCs can shift in flight it stresses the solder joints.
If ESCs can't breathe, they may overheat.
If electronics come into contact with carbon fiber it is possible to short out the electronics.
Remember these rules and mod your build accordingly.
