Here is a Maker Foam plane patterned after the Super Kaos Jr. I did not use an FT style power pod. Motor mounting will require some modeling ingenuity or you can use the 3D printed motor mount that I used. This used the FT Radial "C" pack motor. The servos were some 9g metal gear that I had laying around. A 9x6 prop, and a 4S 2200mah provided loads of power. The PDF plans, the motor mount stl file, and canopy stl file are included below.
This plane flew excellent. Sorry for no video.
If you decide to build one, let me know if you have questions.
