F-86 Sabre - 50mm EDF
CrshNBrn
But I only have a 50mm edf and I’m not really a novice pilot but I have never flown any edfs
Then go for it. Its just foamboard, after all. If you do, I'd recommend burying the servos in the wing (maybe with a servo arm protector) or even putting them on the top of the wing so that they don't scrape on landing.
TB__RC
Ok I’ll do that. I downloaded the plans and I don’t see the *thrust tube* there do I have to make it myself?
CrshNBrn
I did. I just wrapped it around the outside of my EDF and ran it out the back with a slight taper. Once everything was put together, I trimmed it up flush.
synjin
But I only have a 50mm edf and I’m not really a novice pilot it’s just that I have never flown any edfs
It’s a pretty easy build and mine flies great. I did have to put the battery WAY up front to get it to balance.
leaded50
on a 50mm EDF end of thrusttube should be approx. 45-47mm opening on out. This measure is more specific needed for best function on 5/6 blade rotor...... than on eg. 12 blade rotor.
TB__RC
Im assembling the plans and I wonder what this is? (It’s the box with the blue circle)
TB__RC
That is the shelf that the electronics sit on!
@TB__RC i say go for it! it's just foamboard, but you do need to make sure that the airplane is balanced. A little noseheavy is a good idea.
I’m going to use a 1500mah 4s you think it will be good? And I’ll use 6gram servos in the back and 9gram servos in the wing
Zephyr1
Yeah! That's the same battery i used on mine, just make sure the C rating is higher (not like 30) and i've used 9g servos for all 4, so you'll be fine with 6g ones for the tail.
Zephyr1
Done! The tail has a little to much angle because the fuselage had that angle but it may act like dihedral. The wing has a slight down angle I don’t know if it’s going to affect the flight performance.
It won't matter if there's too much tail dihedral. The wing should have a bit of dihedral as well, not anhedral. But i would echo
@chobson303's point. Just send it.​
