MAIDEN - MAIDEN - MAIDEN
Last night I finished installing the battery, screwing on the longer wings and connecting the Rx. Looks pretty complete, except for the belly covering that will come after everything is air-worthy.
I got up at 5 am (regular time) looked out the window and what did I see - calm and overcast - perfect for a maiden. Lumbered downstairs, started a battery charging, took shower, got dressed, ate breakfast on the deck overlooking the lake and calm horizon, brushed teeth, grabbed keys and lunch, grabbed flight case and plane, drove to the field... put on capcam, set up field cam tripod, prep plane... took deep breath.
Maiden - Maiden - Maiden
So, now I'm at work, and hour afterward with feet wet from the dew, writing this so you know some awesome news, that
it flew (probably about 10 meters). I don't know about you, but when things don't go perfect my brain freezes a bit, I just lost my nerve and let it go down. I'll post a video very soon which may add to my recollection... One initial problem is that the wheels aren't large enough to roll over the lumpy grass and the plane is so balanced that any thrust causes the propeller to cut grass/dirt. I think this can be overcome by moving the landing gear forward a bit. Once the plane got rolling it seemed to go pretty OK - except for the left turn tendency.
I would like everyone's insight/comments/training why a plane turns left at the very first of throttling up and then seems to go straighter when airflow hits the tail. Should I add right thrust to the motor?
In short, the plane took off 70 to 80 degrees left from initial nose direction. Taking off the side of the runway is not new to me, but since it was started heading the wrong direction, I backed off the throttle --- just at the moment it got air born. I couldn't recover fast enough and it took a tumble in the tall grass off the edge of the runway.
CRASH
Damage Report
I'm very happy to report that the damage is minimal, broken propeller and mud/grass on the underside of the wing - so it will fly again. The good news to me is that it was very smooth takeoff, meaning it didn't seem to have any really strikingly bad tenancies - like nose up or roll uncontrollably - at least I couldn't tell from the short flight so the video will be instructive and illuminating. I thought it was very graceful for the flight it had, so there is HOPE!
Plans for tonight
- Post Video
- Contemplate moving landing gear forward and making wheels larger.
- Review video - look for tendencies after wheels up.
- Add some right thrust to motor (unless I get some feedback saying this is not what I should do)
- Design some decals for the tail.
- Install rear belly plate.
- Design front belly plate battery hatch.
- Paint wings blue - if the paper starts to peel, I'll be peeling it and glassing.
