newpilot01
Hey guys,
Been lurking the forums for a few days, yall have a great community. Flitetest is one of my favorite youtube channels… often catch myself watching flying toasters and insect-like rubber band planes slowly circle around the room when I should be sleeping. (I also want Josh to drop that Pepsi can) The stuff they do is fantastic and they constantly reference these forums as a leading pool of knowledge for rc flying so here I am.
About two months ago I got my first ever rc anything into the air, here’s the loadout
Hobbyking sk450
CC3D flight control board
Turnigy 3300mAh 3S 30C
Turnigy 9X tx/rx
Hobby King 20A ESC 3A UBEC
SunnySky X2212-13 980kv
loadout website: http://myfirstdrone.com/build-your-first-quad/
First flight was in my room, broke a light bulb, a blade, and scratched the ceiling. Flights 2-10 were in a dusty parking garage where i flew into a brick wall at near full speed, turned the attitude up on the board so I could do “blade drags” with the 10” apc props on the ground if i changed direction fast enough, discharged the battery till the blades stopped spinning… I did not treat it well (got 14 broken blades 8-10” here)... yet for a while it flew amazingly. Took it in a big field and zoomed out past 100m line of sight no problem. Lots of power, ~13-15 min flight time, very stoked, began looking into fpv systems. Around flight #15 is where the uncontrolled acrobatics started happening…
After some time (~30 seconds) hovering, the quad would violently flip and land on the ground. After righting it and picking the dirt out of the propellers/engine bells, it could take off then flip for no reason again… I noticed that engines 1 & 2 were making grinding sounds and sometimes would be hard to turn using fingers. Took of the c-clamp… opened em up… noticed flakes/shards of silvery, magnetic material on the inside of the outrunner magnets… removed the material with a toothbrush… reassembled… grinding greatly reduced… armed CC3D… throttle… esc 1 produced two large sparks followed immediately by thick white smoke.
Did my engines seize and cause my quad to fall from the sky? Did i reassemble the engines wrong? Could it be the tx/rx? I'm thinking of getting four new engines with 30A ubec’s and treating the quad much better this time. For Christmas i bought the dominator v2’s, a new pulse 3300 3s 35c, and the DJI 450 flamewheel frame so I want to diagnose the flipping problem and fix it before I break any new things. Any input is greatly appreciated.
Thanks for listening,
newpilot01
Inside of engine 1 before the metal shards were removed.
My new tricopter post unexpected acrobatics (fixed the arm with cotton+JB weld)
Hobbyking sk450
Turnigy 9X tx/rx
newpilot01
