Here is tonight's progress, getting the plans ready for cutting.
Hopefully tomorrow.
It is my entry as well. I am about 90% done with the assembly and hope to start painting once I get back from being out of state.
It is a good clean build.
Carl’s build video is really good. I put the rear servo tray in before the rear turtle deck. Then installed the elevator and rudder pushrods and servos in as well before installing the turtle deck. This made the task a breeze.
I use the yard marker flag wires for pushrods. The aileron pushrods needed to be bent with a couple 90 degree bends to keep from binding the servos. Essentially putting in about a 1/2 inch or so step in the pushrod. The control horns sit quite a bit lower than the servos. The marker flag wire is plenty rigid and handle the bends without flexing. A lot of ways to do it…this just worked out well with the FT wooden Control horns I have.
That was about it. I hope this helps you out in some way.
Enjoy the build. I look forward to some pictures of your progress.
