Bando FPV
Hey Flite Test enthusiasts!
For all Taranis X9D AND Q X7 fans out there that want a little Flite Test touch to their radio, you're in luck!
I created a Flite Test Splash Screen that will be shown everytime you boot up your transmitter!
Here is the file for the Taranis X9D & X9D+ Splash Screen: FTX9D.bmp
Here is the file for the Taranis Q X7 & Q X7S Splash Screen: FTQX7.bmp
Before you upload the splash screen, you need to update your firmware AND SD Card to the latest release. Here are two great videos that will teach you how to do so:
Now, you can upload your new splash screen, here is a great video:
NOTE: The videos are for the Q X7 and Q X7S but the procedure is the exact same for the X9D and X9D+.
WARNING: Make sure you use the proper Splash Screen file for your model of Taranis. It will NOT work if you use the wrong one.
I also added FOUR Flite Test Sound Effects. One is the short Flite Test intro music that can be played on boot up. Another one is the famous Josh and Josh "HI!". The third one is Josh and Josh saying "Rocket Plane!" from my favorite FT episode. And the last is the old long FT introduction.
I highly recommend you to add the Amber Sound Pack to your radio (it's just way better IMO). It's not required, but if you're interested, follow this video:
NOTE: You can't use the Amber Sound Pack for languages other than English.
The instructions for where to upload to your SD card are next to each file linked.
Here are the Sound Files:
Short Intro for boot up: hello.wav (Add to your SOUNDS/en/SYSTEM folder. NOTE: you will need to REPLACE your existing hello.wav file with this new one!)
Josh and Josh Hi: FTHI.wav (Add to your SOUNDS/en folder)
Rocket Plane: FTRP.wav (Add to your SOUNDS/en folder)
Long Intro: FTIntro.wav (Add to you SOUNDS/en folder)
Here is a video of the sounds all working:
WARNING: If your radio uses a different language other than English, make sure you add it to the right folder. For example, for French use SOUNDS/fr
NOTE: I only tested the Splash Screen and Sound Effects on my Taranis X9D+. If you have any issues with the files LET ME KNOW so I can update them!
If you want a different favorite Flite Test sound file on your Taranis, feel free to let me know and I can make one for you.
I also created a Flite Test Betaflight OSD Logo that you can add to any Betafligh Flight Controller. Simply navigate to your OSD settings, select Font Manager, and upload the Custom Logo!
Here is the Flite Test Betaflight OSD Logo: BTFT.bmp
NOTE: Video of it working is lower down in the thread!
Enjoy!
UPDATE (1/19/19): Added a Flite Test Betaflight OSD Logo
Enjoy!
