Took out the BW this morning, had some wind so it was take off and landing practice in the wind. I did dial the expo on low rates from 30% to 15% and it made the low rates a lot more responsive, just like being on high rates just not as much throw. Gonna try this on the rest of the planes. I also found out that half flaps will pitch the plane up, while full flaps will tend to pitch it down. I did some tests in the air before take offs with flaps and full take off flaps will be counter productive so I might dial the travel of full flaps back a little to find a balance.
One other thing since flaps are on this model, I do like the STOL and slow flight benefits, but I think the under camber wing tips are to long for flight in a breeze. It is just way to sensitive to wind so I am thinking of trimming 2-3" off the wing tips so it doesn't have the same sensitive leverage in the wind or with contact with the ground. Which did happen and caused a small tear in the wing where the under camber meets the LE fold, always a weak spot on these wings.
