Matagami Designs
I learned to solder in Electronics class in High School. Super careful with the soldering iron, just enough heat to do the job. Very precise and pretty difficult. I was having a bear of a time soldering the connectors necessary for these birds, when my uncle, @sundown57 shared a bit of wisdom. Not a soldering iron. A soldering gun. High heat. As high as it will go. Use the flux. Not just the flux in the center of the solder, actually use a can of flux and liberally coat either end.
Coating either end in flux and just touching the hot tip of the soldering iron? Boom. Solid joins in almost no time at all. Not nearly enough time for the heat to damage anything. It's nearly instantaneous. It was a serious game changer for me.
Yeah I watched a instructional video a few weeks back and realized that the heat wasnt transfering because my tip wasnt tinned properly. I eventually got the job done but the connectors were quite distorted. I picked up a can of flux today since I knew this was immenite. Hopefully I can tin it better now. Just need to pick up some bullet connectors. The edf motor has 3.5mm and the esc is 4mm... Sold this way as a kit. Jerks.
