MAIDEN SUCCESS X-29
Well I have the completed the maiden. It flew very well. the gusting wind made it a bit scarier than it need to be... it did crash, however managed to do it soft enough to effect no/minimal damage. (had to wipe some soft loamy soil from the nose tip.)
I can't wait to try this again in more calm weather. Later
Maiden:
I will also put the on the build page. Now for the post event evaluation...
Build
This build had 7 sheets of board and a large number of parts. the fuselage and wing are in a number of sections. lining these up isn't always perfect, and pressing some parts into place may cause a failure is the glue isn't solid. That is the primary reason I taped the SNOT out of this plane. also Everything needed to be extended. and the junction spots are the very back of the nose section this is REALLY hard to get at and reconnect. I'm not really sure how my battery lead will be reconnected with out a "maintenance hatch" created.
Rating: Challenging build
Flight
She flies, and flies well. Two things I noticed. Loops and elevator control is Very limited. so, Either more control surface or larger throws. I will adjust the rods for more throw and see. It flew great slow and better fast. except in a dive. which was slow to come out of. Every one I would think there it goes, I be rebuilding this one later.
Rating:I would have this be a moderate flier. It's very different control rates and slow elevator controls make me feel it might even be hard..
Stop Start Continue
STOP
Putting pieces in backwards. Maidening on a gusty day. A couple times I thought this plane was a surefire gonner.
Start
More details on the wings attachment would be helpful. I ended up with a large Glue filled gap. Adjust the Elevator controls to get slightly more control, and plan to reduce aileron end points to reduce the relative roll capacity. Put a Velcro strap to keep the battery in place. (however, I think the impact shifting battery does absorb a great deal of energy. and my be what allows me to fly this on Sunday. in the build it would be helpful to show the end result and point out what will be important to not. the recap just before the previous step is complete.
Continue
Tuning the controls. I remember they talked about the controls looping being slow, but I didn't expect it to be like it was. robustness. the wings feel VERY solid and it's a good thing. Taping the model took a while but has been worth it.
Note the throttle linked LED ring would be righteous in this model...
Maiden:
Build
Flight
Stop Start Continue
STOP
Start
Continue
