Coming along...
The Sea Duck is a pretty intense build (maybe the hardest one I've tried to date.) Not impossible, just a lot more "Might have to trim" occurrences than other builds.
Started on the seaduck (my 1st) this weekend, got about half way maybe then realized I needed to prep electronics (I'll add a write up to my build tonight.) I plan on wrapping that build and getting the Mustang done this week... That just leaves the Legacy (but I still need to do the cut files for that.) I've been mulling around the idea of a 75% version.... The landing gear I have would look pretty anemic on a full sized version!
I'm now on the fence with taping the whole aircraft... Maybe it's just the geometry of the sea duck, but I've gone back and forth between covering before assembly or after...
If you do it before, you have to cut away the tape where you are going to glue...
And here you can see I waited to cover the fuselage top until after it's joined to the bottom... (Now, wondering if that was a mistake.)
The weather looks pretty horrific here for the next two weeks (at least for my skill level) getting maidens in before I have to travel for work (25Feb - 1 March) might also be a problem. I'll get my builds done, just have to see about weather.
