SGrog
I'm no programming expert myself, but is there anyway you could either post the code somewhere, or pm it? I should be able to take a look at it tonight and let you know if there is anything that stands out to me. How did the ESC calibration go if I may ask?
Other questions that pop in my mind are:
-What edition of GUI are you using?
-Are the signal wires from the ESC's in the right spot on the board? (typically signal is on the inside of the board, then negative, then positive if memory serves correctly)
EDIT:
For the Aux 1, do you have a cable going from Rx to the board for the Aux one channel? That is how I have mine set up, and on my set up, Aux 1 on the Mwii goes to gear on the Rx, and then under the GUI, I have the high position of the gear switch set to arm it. After hitting the write button in the GUI, that is how I Arm my copter.
EDIT:
