FDS
I thought you said you had EV800d goggles? They have antenna diversity. The EV800 is the single antenna version.
if you are going to continue going beyond line of sight then safety should be the primary concern, which means a ground station as suggested above, along with a better receiver module to go in it and means of linking the ground station to your display/goggles. If you put the receiver antenna higher off the ground, the signal will be better, that’s why ground stations are used, as you can put them where reception is best, unlike goggles on your head.
Doing long range safely is expensive, there’s no way around that other than to fly less distance with cheaper gear.
Note also points on legality, with restrictions in place on pilots the authorities will be looking to hammer some poor schmuck to make a point, don’t let it be you.
Also, no point in looking at anything until you have thoroughly tested the components of your existing system. It could just be a $15 antenna...
