2.5g? How about 1.7g? When I built my 5g-motor-powered 50% Versa wing, I used 1.7g servos -- the ones with the little molex connectors that go with the micro version of the "Orange" receiver from HK. And I used 3mm Depron for the build. Link: http://forum.flitetest.com/showthre...2-2-ounce-AUW!&p=144131&viewfull=1#post144131 It uses 2S and so is quite zippy. I flew it at FF15 (and it got midaired...but not too bad damage). What type of foam are you using? If it's DTF, I assume that you took the paper off both sides.
Thanks for the info. I didn't have any smaller servos on hand but I will be offering some of the mentioned 1.7g to test with.
I am using DTFB and for the first build I've used a combination of removing and leaving paper on. I will shed paper as needed during testing to see what performs best and is the most durable.
