She flies!
localfiend I like 3D printers... Mentor Sep 13, 2015 #62 nerdnic said: She flies! Click to expand... Awesome. These little micro planes are a ton of fun.
nerdnic nerdnic.com Mentor Sep 16, 2015 #63 Maiden flight Tail heavy and inadequate throws, but she flew! I put a bunch more batteries through it to dial everything in. Beta plans and more video coming soon! https://drive.google.com/open?id=0B_Fcnulg3xtrTkRWeDBhNDFtcUk
localfiend I like 3D printers... Mentor Sep 19, 2015 #66 Cool. Hopefully I can get around to building one of these this weekend.
nerdnic nerdnic.com Mentor Sep 21, 2015 #67 I have a few changes to the plans I'll be making soon. If you've not started your build yet, wait for v1.1
localfiend I like 3D printers... Mentor Sep 21, 2015 #69 I printed out the 1.0 plans but didn't get anything cut yet. I'll wait for 1.1. What motor and prop did you end up with? Looks like you added in some right thrust as well?
nerdnic nerdnic.com Mentor Sep 21, 2015 #70 I'm using the NTM now but I've got the hexTronic on order. Yeah a small amount of right thrust is needed.
JohnRambozo Posted a thousand or more times Sep 21, 2015 #72 Impressively diminuitive. I bet sanding the leading edges would do wonders for flight performance.
nerdnic nerdnic.com Mentor Sep 21, 2015 #73 On the first beta I did bevels on the leading and trailing edge. I will test to see if it makes a noticeable difference or not.
localfiend I like 3D printers... Mentor Sep 25, 2015 #74 I'm testing some other spray adhesives. E6000 may or may not have been a good idea. I'm assuming the rest if the parts are posterboard? Got any pictures of the motor mount arrangement before the cowl went on?
nerdnic nerdnic.com Mentor Sep 25, 2015 #75 The pod is actually poster board. Are you looking for a photo of the motor and pod installed?
localfiend I like 3D printers... Mentor Sep 25, 2015 #76 nerdnic said: The pod is actually poster board. Are you looking for a photo of the motor and pod installed? Click to expand... That would make it lighter. And yeah, that's what I'm looking for a picture of.
nerdnic nerdnic.com Mentor Sep 25, 2015 #77 Yeah, the pod doesn't need to be foam. Also, the battery wouldn't fit either. The doubled poster board works very well. Let me grab a picture of the pod/motor.
localfiend I like 3D printers... Mentor Sep 25, 2015 #80 nerdnic said: Let me know if this helps: Click to expand... Yep, that helps. Thanks.
