This build started as an effort to make a companion for my friend's Spitfire. I found that user Ultramicrobe already made modifications of FT Spitfire plans that make it into Messerschmitt Bf-109 ( article on FliteTest ).
Since I'm a novice scratch-builder, I applied Ultramicrobe's modifications directly onto original FT Spitfire plans, so I would have less to worry about when cutting and building the plane. I think these plans could benefit more builders, so after today's maiden, where I made sure that the design works, I decided to publish them.
Plans:
Build process is almost exactly the same as build of FT Spitfire.
Painting
Moving to field
The painting job is kind of messed up (yellow overspray is showing on parts of the wings), but it is noticeable only under some angles.
Next, I need to finish canopy. If you have any ideas on how to make nice Bf-109-like canopy, I would welcome them.
I hope you enjoyed this post and possibly will build the plane and enjoy it even more.
Plans:
- View attachment Re-Tiled Messerschmitt BF-109 P1.pdf
- View attachment Re-Tiled Messerschmitt BF-109 P2.pdf
- View attachment Re-Tiled Messerschmitt BF-109 P3.pdf
Painting
Moving to field
