Bob A
O.K., I've made a few posts here, four so far, of little consequence, but now I need to post something of importance - I think.
I finally got around to printing, taping together and cutting out the plans for the Mini Guinea. I then made a kit from Dollar Store foam board and built the plane, except or electronics, still waiting for the arrival of some servos. Big problem is, the trailing edge of the wing is approximately 3/8 to 1/2 inch ABOVE the fuselage!?! (Confused)
The ONLY thing I did in variance from the plans was to use a yard stick in place of the paint stire stick, it was wider then a stir stick but the same thickness. I did not allow for this variance by changing the airfoil indents on the inside of the wing before folding.
I see two choices;
1) Build a new wing; going to the hardware store and getting a "real" paint stir stick to use for the spar.
2) Slice the rear edge of the wing part way through, aft of the bottom sheeting (which would correspond to the aileron width) and re-glue it to be level with the bottom of the wing skin.
One way or the other should do the job admirably, giving me a 'flat' wing assembly.
Thoughts would be much appreciated.
Bob
I see two choices;
Bob
