Wow, that's awesome!!! I love the idea.Since I was afraid the Twin Smoker wouldn't work, I was thinking of other ways to salvage the design, since it looks so nice..
So here is what I came up with.
Some of the older guys will know what Im talking about here.
Growing up we would always get these Siren Whistles toys as like stocking stuffers and party gifts and stuff.. https://cdn.shopify.com/s/files/1/2121/1463/products/Sirenwhistle_grande.png?v=1593139527
It's just a plastic tube with 2 disks inside. One disk is stationary and full of holes, the other is a small turbine shaped disk.
When you blow in one end, the turbine spins and makes a super loud Air Raid Siren kind a sound.
So, with this in mind, I only modified 2 parts and was able to turn this into a massive Siren Whistle.
And this one actually works too.. LOL Its really loud just blowing in it.
Using an Anemometer, I measured the minimum wind needed is about 10mph.
Plus, the hollow body acts as a resonance chamber, making it even louder.
The faster the air going thru, the higher the pitch.
I needed the turbines to spin fast and freely, so I took the bearings out of a burned out brushless motor. They are 8mmX4mm with 3mm hole.
Tryin to make my designs Community accessible, so I want to use stuff we would all have laying around.
Assembly is easy: (all new parts print without supports.)
- Using 2 M3x10 screws, attach the bearings to the Siren Turbine Supports. Make sure the screw head is not too large, it needs to snug up into the turbine. See Cross section view to see what I mean.
- Using the Siren Support Instal Tool, press/glue the Siren Support into the Shaft hole of the Main Body.
- While using the Install tool for support, press fit the Siren Turbine onto the Bearing. Making sure they arent rubbing on anything.
- Insert Servo Plug to plug up the hole for the Servo (if its not installed).
Yes, I created a Servo Hole Plug, so you can also plug up the servo hole if using this just for Looks.
In the Attached Cross sectional view, the White parts are the new parts.
Hopefully this give you guys a better idea of how it all goes together.
So there it is, the Twin Howler!
Now you too can go out there and annoy everyone within 100yards of you!.. LOL..
The main issue with the smoke generator is realted to the incoming airflow. Increasing the size shoould work!Yeah, I feared it wouldn't..
Who knows t ho, maybe mounted on a plane doing 80+mph..
The vibrations and movement might help shake up the powder so it flows better.
Just a suggestion, you can use the servo to control when to allow the mechanism to rotate freely, this way you can turn on/off the whistle.
This is ridiculous. I love it.Ok, thanks to cdfigueredo's suggestion; I present to you: the Twin Howler - Iris Edition...
I cant believe it actually works.LOL.. Its a pain to assemble tho, lots-o small parts...
And tolerances are really tight too. There wasn't a lota room to fit the mechanism into the intake, but somehow it fits.
I also managed to only modify the Intake part. So all the other STLs remain the same.
Just print and assemble the Iris Intake and clip it on in place of the normal intake.
Ill put together the files and a write up when I get a chance.
There is a specific Order of Operations for assembly, so I want to make it as easy as I can for you guys.
These designs are quite dependent on tight tolerances for pivots, clips, and other pieces that press-fit together, etc...
Im always worried about that when I release files to the public.. I try to keep the tolerances around 0.25mm.. I figure thats a good middle ground.
Everyone's printers will have different tolerances tho, so some pieces may not fit together like they should, or at all in some cases.
So, I apologize in advance if these things dont fit once you print em. (assuming anyone out there is actually printing these things..)
Probably, but at the cost of complexity tho. One of my goals was to make the project easy to print, assemble and use.Coould you put in auger or a second axle outside the main one with stirring sticks on it, controlled by a servo modded to spin 360 to keep the powder free and loose?
i'll think about your idea, and see what i can think of too.Hello people!
It's been a long time since we last posted something in this thread, however the idea hasn't left my mind. I have been rambling about some ideas without coming up with anything useful, but recently I found something that might work and I would like to get some of your very helpful opinions.
First I would like to list some assumptions that will serve as a basis for us to overcome this together and achieve this super fun for our electric airplanes.
- It has to be lightweight. The last prototype scaled to 150% printed in PLA weighed about 150 grams without the weight of the powder. that is unacceptable for most small airplanes.
- It should be able to be replicated without the use of a 3D printer. Of course the prototypes will be designed/printed in 3D but the main idea is to find a technical solution to the problem.
- There is a factor that at least I ignored until a few days ago, and that is that powder, as well as liquids, react to inertia and are therefore pushed backwards during flight (this can be very useful).
- The airflow we are using to power the device is very little and is affected at low velocities which is attenuated against the amount of smoke we can obtain.
- It has to be simple
That said I have been thinking about several solutions and I think I have arrived at what could be the final solution, however I still have my doubts about it.
Solution 1:
Use an Archimedean screw to push the talc out of the storage compartment and mix it with the airflow outside the aircraft. This mechanism goes against point 2 and 5. In addition, a servo would have to be modified to move continuously and the speed could empty the compartment in a few seconds.
Solution 2:
Use a closed compartment with an elliptical or conical shape so that the talc is pushed towards the outlet (red part) due to inertia. The red part would somehow dispense the talc and expel it into the air stream generated by the model's advance. View attachment 232723
This variant involves a very simple operation that would only require a servo to open or close the (red) output. However I am not sure how the smoke output would be, I think it could be quite messy. It was then complemented by this other version that increases the air flow pressure directly at the smoke outlet.
This solution relies entirely on the dust always accumulating against the exit mechanism due to the inertia of flight, however this may not occur at low speeds or once the dust has reached model speed. So this forces me to think about version 3.
Solution 3:
Based on the previous solution the proposal is to add a small hole in the front of the powder container to allow air to enter and thus push the talc always towards the outlet. The main problem here is related to the diameter of the hole; if it is too big it would generate a lot of drag and also the powder would escape from the front due to turbulences, but if it is too small, it would not fulfill its function.
So what do you guys think? Does anyone have any fresh ideas? Is this thread worth revisiting?
Last time this deserved us an appearance in one of the Flite Test videos, I think if we manage to get something concrete we will surely show up again.![]()
Nice!!! this is the spiriti'll think about your idea, and see what i can think of too.
i have a couple ideas in mind.
Matthewdupreez you were never able to get the videos or photos of this test, were you? I really would have liked to see it in action.@cdfigueredo my friend printed and tested one. No video unfortunately. But it works really well. He increased the size of the outlet hole. To create a vaccum for the powder. And it works!! Really well.
Only thing was (may have been a side effect of increasing the size of the outlet hole) that it didn't last very long. About 12 seconds.
And this was the 150% one I believe. So the capacity is about 200 millilitres.
But it certainly works and it's beautiful.
I think that possibly if the hole was kept smaller it would have lasted longer.
BUT YES IT WORKS!!
Solution 3:
