SO MANY PROP ADAPTERS
ElectriSean
Eternal Student
I would use the included hardware and try to find some M6 nylock nuts rather than the nuts it comes with. Doesn't look like HK carries them, but they should be available locally.
Ricci
Which adapters cames with the motors. All CW ?
If this is the case you can not use locknuts to operate CW motors as CCWbecause there are no 6mm locknuts for CW threatened shafts.
But you can use props that are screwed with two screws to the motor and you dont need prop adapters. The counter plates to mount are included in your motor set.
The props looks like this 12"
