Yeah, I was pricing all the components this morning and think I'll get them all from Balsa USA, even though there are a few choices that are about $1 cheaper per piece. And as mentioned previously, the rigging wires on this plane are absolutely required. Even just sitting on the ground in the pits waiting to fly, without the wires the wings would collapse.
The wings will need 12 turnbuckles total, plus another 4 at the center section of the wings, plus 2-4 more for the landing gear. So basically 20 pieces.
Plus the new wire, but decent wire is still fairly cheap at around $0.30/ft, and I'll end up using around 50' or so.
You can't simply tie the cable in a knot to fix the ends, and in my case I'll be using a Nicropress tool to crimp a sleeve over the ends. Another $52 for the crimping tool, some sleeves, and cable as a "starter pack".
One item I'm not looking forward to buying are "thimbles" for the ends. The thimble is kind of a loop that the cable goes through to keep from making a sharp bend at the end. These pieces are deceptively expensive at just over $1.10 per piece (expensive for how small they are, I guess). They are used at each end of a wire run, so each wire has 2. Figure close to $40 worth of these pieces. The problem with using them in this case is that they require a 1/8" hole. Most of the wire mounting locations are no problem, but there are 8 spots where two wires are very close together and that may cause clearance issues. Using them would require replacing some hard points, which wouldn't be a big deal.
So the short version of all that is that to re-do the rigging wires with turnbuckles and fancy compression sleeves on the ends will run me close to $200. However, 25% of that is for the tool to crimp the wire so I'll have that for future builds. (Look at me justify the price!
Most of the rigging wire ends right now are simple DuBro metal clevises. While plenty strong for a pushrod end, I don't have any warm & fuzzy feelings about trusting a 30 pound airplane to them, especially since it's very hard to see some of the ends to know if the pin is even clipped in place! They have some adjust-ability, but some pieces are bottomed-out and can't be tightened anymore.
