RockNBurn
*EDITED*
I have not yet given up on this plane. I'm just having some time/budget constraints.
But I have some news. I made a Phoenix RC model. It may have some problems, but it FLYES!!!
Download it here.
Enjoy.
REMEMBER, THIS PLANE IS STILL UNTESTED
To download the plans, please, click here.
Some assembly notes before I get some instructions done:
What I just fixed:
Added a slot on the body to fix the vertical stabilizer.
Neck collar is 5 mm too wide on the base. It wont go into the body
Wing slot does not seems to be wide enough to hold the wing.
Added a slot for the cabin former.
What needs to be fixed so far:
That's all, I guess.
*Original Post*
Hey guys.
First of all, I want to say thanks for the Flite Test team and community for making it easy for anyone to start in the hobby.
And also, sorry about any bad english, LOL.
I always liked airliners, specially classic planes, so I decided to try to make a swappable airliner, based on my ll time favorite, the Douglas DC-3.
I'm modeling the body on Blender 3D, using FT build techniques. Some parts will be based on the FT Cruiser, but probably I wont be using the full sized power pod (maybe the mini power pod, or a custom sized one).
I really, really hope I can finish it, since its my first scratch project. Unfortunately, I don't have access to Addams Foam-board here. Mays I'll make mine out of Depron.
I'll be posting my progress here.
These are just a rough approximation on the body structure. As soon as I have figure it out all the parts, I'll be detailing it.
Download it here.
Enjoy.
- Install the tail turtledeck AFTER installing the push rods. You will need to punch holes in the postboard to pass them
- I did not included any piece to hold the pushrod tubes (or whatever they are called). Please, make you own.
- In the mid wing section, there are 2 access hatches. The front one is for the motor cables, the back one is for the servos (flaps and ailerons)
- On the spars, the middle section spar reinforcement is placed facing the tail, and the wing spar reinforcement is placed facing the nose. (The insert tabs on the middle section have different sizes to prevent it to be placed backwards *hint*hint*)
- The wing assembly is identical to the FT Spitfire. I've included a Dihedral Gauge. The tab should be placed on the wing Camber.
- Aileron servos are placed on the Wing Camber, but you must cut a servo pocket so they can fit. (see FT Spitfire)
- The nacelles have a C fold to add a down thrust angle. I forgot to add the C Fold Icon.
- There are still no landing gears.
What I just fixed:
*Original Post*
Hey guys.
