Here is a scratchbuilt American Bald Eagle slow flyer. This design is super easy to build and uses a KFM3 wing. I am using a hextronik 1200 kv blue wonder and a APC 8x3.8 SF prop and a 1300 3s battery and uses a standard FT power pod. AUW is 570 grams. I am flying this as a RET altough ailerons could be used but this plane responds superb with just rudder and elevator. Perfect for lazy flying and looks great in the air.
jamboree1
Thanks for posting this here. I've seen one like this flying at Flite Fest last year and thought it was pretty cool. I'd like to rework the plans for DTFB, add the FT power pod, maybe add some A or B folds for the fuse, servo locations, etc. Do you know who did the original design? I'd like to get permission to reformat the plans so that I can share them with everyone else. Thanks.
Ok Sponz, here ya go, hope you read and speak german, lol anyways http://www.rc-pilot.at/hp/index.php?option=com_content&view=article&id=60&Itemid=76 Its 5 years old and in another country, so I wouldn't worry much about permission. Incidentally a standard FT power pod fits right in snug as a bug in front. I used a piece of foam board in the back of the pod as support, and right behind the pod is where i put my servos. Those plans are for a v-tail, I really aren't fond of v-tail as main form of controls and i didn't want ailerons with this wide wing design so i just laid the 3 pieces flat as T tail. When it came time to layer the wings together I used a craft foam glue as opposed to hot glue for weight savings and a bit more time to align the pieces. This plane deffinitely needs your touch to the plans for ease of build, especially the fuselage folds.
The dihederal in the wing tips will most likely keep the flight level on it's own. I did not use ailerons because I don't believe they would be much of a use with this wing design other than bank turns. Also with this being a solid wing it would make it harder to mount and run wires as opposed to an open wing, so much of this is due to ease of build. With the way you want to build your wings as detachable I say go ahead and leave the dihederal out where they join, try it with just the wing tip dihederal and see how she handles as it would be an easy thing to add dihederal later.
Thanks Jamboree, I will try exactly that.
BTW, Did you make the curve that was in the plans for the wingtips or did you just bend them straight???
I seems like it might be difficult to bend the foamboard on that curve,
LooseBruce
Actually Jam ((hope you don't mind me calling you Jam) I think I will try it with the wing tips bent up first. If that doesn't do it I will recalibrate my thinking.Now that i think of it, if you plan to use ailerons you won't really need dihederal at all
Thanks Jamboree, I intend to sand the leading edge though I have been putting it off. I think with all the time my wife put into coloring I'd better build only oneLooseBruce, the bird sure is looking good, as far as the wing design goes it will be a trial and error deal. get it flying on original design then build another wing to see how it goes. Also note it doesn't appear you sanded the leading edge of the wing at about a 45 degree angle, check my pics for reference
Thanks for your input.I have limited traveling storage and would like to protect this big bird.It is a protected species! I folded on the bottom so the hinge would go the entire width. If I permanently fold up the wingtips the finished folded wing will be thicker than I want. I am still thinking about it though. Your thoughts are helping me.While writing you I had the idea of thickening to 3 layers of foam the wing above the fuse. Then I could hinge the top and possibly build in the dihedral.I did not have any problem with the wing tips on mine, just ran the skewer over the curved cut until the flexed up enough for the proper angle. I filled the gap with hot glue and let it set.
I used a sealing iron to round the leading edge on my bird, helps the looks.
Might have to try the folding wing in the future, mine is pretty beat up from transporting it.
