So today we went flying me and
@Eddo radush! It was a blast at least for me. We met up pretty early something at around 7:45 am at my place and did some checks on his TT to make sure it was ok before maiden, as well as finished adding seperate flaps to my Simple Storch wing. We wasted quite some time at home and left the house only around 9 am. We arrived at the field and started off by flying our TTs. I was flying 4 channels and he was flying 3 channels. Its was a blast, we each flew a whole battery. I have three 3S batteries so was good for another round but he didn't so we put our TTs aside and put his battery to charge from the car battery directly.
@sprzout I was afraid for no good reason b/c it chraged like a chram and was much less intimidating then I thought it would be.
While we waited for his battery to charge, we took a break for water and coffee which I brought from home and prepared to setup my Charlie as per
@basslord1124's request for a first madien after a previous bad attempt, considering he was the only one that voted his thought about it
Now a question for all you folks. Mini Sparrow or Charlie what should I take with me tomorrow?
OK, STOP! This moment is another good moment to thank
@kilroy07 and
@buzzbomb whom without this wouldn't have even been an option
, so thank you once more. I will thank you each time the Tx is used when my old Tx didn't do the job
. I pulled out a YouTube video about setting up elevons and started working it. What I didn't know though that the Rx would be bond to only one model on the Tx and cut up a Y harness at the field to try and make a bind plug, which didn't work
. Switching back to the TT model on the Tx worked so I change the setting of elevon mixing on that model and gave it a go. It flew this time for more than 10 second
but didn't fly well because the ESC was not calibrated, plus I broke a prop but that was ok cause I had spares
. Tried calbrating the ESC at the field but ended up with an ESC that won't throttle up at all
. Got to figure that one out!!!
ANY IDEAS?
Ok so back to the TT as
@Eddo radush's battery was all charged up by now. We setup the TTs again and went flying, trying to fly one after the other. The wind picked up by now and it was sort of gust in one direction, would start and stop on a loop
. We flew the whole batteries again, only this time I finished up another half battery before wrapping it up.
@Eddo radush also broke his prop saver band and didn't have another one, rookie mistake. Oh well he'll learn for next, won't you
? Remembering a post by
@Hai-Lee about using the ends of ballons as prop savers I told him to think it over as an option for next time.
Ok so what next, are we calling it a day?
Hell NO!!!! I still had one more supprise up my sleve I had the Simple Storch. So I pulled it up and started setting it up. It took some time to figure out again, but I did it, half job though because my flaps only worked on two channels of the the channel switch they were on. Again thank you
@kilroy07 and
@buzzbomb another option my old Tx didn't have
. Ok so hand toss or ground take off? Of course ground take off! I don't know how the take offs are for you
@Arcfyre but for me it to about a metter or two to get up the ground at 75% throttle. The first go was tail heavy and made the plane nose up, crashed it to the ground, with no damage
and fixed the balance issue. Second go was much better, tried to get the plane to gain altitude but just couldn't, probably another ESC callibratation issue because this model shouldn't have a problem with the winds which were much stronger by now. The flaps hadn't been used at all because there plane would just hang there due to the wind. I didn't manage to land it and one my last crash even broke the entire wheel holdings and a servo. It was starting to get late so I didn't have the option to fix it at the field even though I could, we wrapped it up and prepared to head home. When we got to my house
@Eddo radush helped my take all the planes up to the my appartment on the 3rd floor building with no elevator
, thanks buddy you saved me the up and down routine.
I acompanied him down to his car and we said farewell but not before setting up the next time we are going flying together
, this coming Thrusday! Yeppy can't wait, excited like a child with wings in the sky
. You are probably asking yourself if we got some videos
. Of course we do, just need to find a moment to edit them, so until then let you imagination work some, trying to turn my story above into something visual. Videos later hopefully today after my afternoon shift
Oh last two things for this post. Today I gifted
@Eddo radush my old Mini Scout airframe, it's a bit smashed but repairable, so we might see another competitor on the
FT Mini Scout Newbie Challenge.
@Eddo radush it would do me a lot of honor if you compete on the challenge
. Second thing is that me and
@Eddo radush have decided to take something like this as a project for slope soaring
@bracesport .
