RotateB4TheEnd
Hey all,
I'm having an issue with my newly assembled batbone tri. I'm using a KK2.0 board.
When doing some throttle ups with the entire system powered up, I'm having an odd issue.
Whichever motor is plugged into the M1 slot (This is normally the front left motor) will continue to rev up to a higher and higher rpm if the throttle is held at a low setting. In addition, whichever motor is plugged into the tail motor slot (M3) will require the throttle to be pegged to get it started and then it proceeds to slow down and eventually stop even though the throttle is set at the same setting.
Any thoughts on this?
Thanks,
Jake
Thanks,
Jake
