One of the challenges of the tractor style, in my opinion, is the abuse the prop and motor can take on landing. I love the flight characteristics of the tractor style, though, so I looked for ways to improve the power pod and the attachment of the pod to the wing.
First thing I did was make my pod from coraplast. This make the pod virtually unbreakable. I've slammed the wing straight in numerous times and the pod is still in good shape. Now making a stronger pod causes the force of the crash to pass into the wing through whatever attachment method you use. The bbq skewers are always the first thing to break so I didn't install them in this build, instead I went with two coraplast angles glued to the bottom of the wing on each side of the pod and run by front skewer through the coraplast and pod. I have yet to have the pod come off. The skewer did crack on one crash but skewers are cheap
You'll note in looking at the picture that my motor is hanging loose. I did have a lunchtime crash yesterday, nosed straight into the ground at full speed. Wing was fine, pod was fine, the weak point was the motor mount screws and for me, that is just fine. The motor popped off saving the motor shaft and the prop from any damage. Screw the motor back on and I'll be back up in the air.
As for the battery, my first time out I did use a 1300 mah battery mounted inside the pod but balancing the wing was very difficult. Instead, I've glued some support sticks inside the pod, run two Velcro strips through the pod and over the sticks and attach my battery under the pod. I've also put a small piece of Velcro infront of the battery position for my battery cell checker. Yesterday's first flight was 11 minutes and I only drained the battery to 11.2 volts. Could have gone for another 5 plus minutes.
The last photo shows the interior layout of the pod. Battery support stick on one end, Lemon 6 channel stabilizer / receiver in the middle right on the cg and the 30amp ESC up front.
Love the Versa!
