TooJung2Die
Good instructional video! I wonder if anyone has used plastic sheets cut from 2 liter soda bottles. It'll be curled but should tape down flat enough.
I'll reiterate something from the instructions. The build tabs for the ribs are on the top of the wing. So the wing is built upside down over top of the plans.... which are a top-down view. So the right wing is built over the left wing plan and the left wing is built over the right wing plan.
As long as you follow each step, you shouldn't miss it but some may associate the text with images and this set of text does not have an image. Read everything. Top Flite made good kits with good instructions.I hope they put that in bold type in the instructions. I haven't run across that method in a kit before and can see myself messing that up really easily...![]()
Sucks about the reaction, you should maybe wear latex gloves alsoIt's progress but some progress was not made in the right direction.
I have nitrile gloves but that does not cover my arms. Someone suggested a tyvek suit, which I suppose would solve the issue but the reality is that the wood needs to be treated as a hazmat. It needs to be sealed up with fiberglass ASAP.
I'm party frustrated with this project because it has been my longest running "big" project now. Normally I'm knocking out one of these in 7-8 months at most. To be going on for this long is driving me nuts. At this stage I think that it probably should just be thrown away but I've got so much time already invested and these top flite kits are not replaceable at this stage. I think I can make it to the finish line as I know enough about microbiology to keep me safe but it is just slow progress.
If it is a fungal spore than isopropyl alcohol will doo very little. The spores are designed to survive even a mild-grade nuclear apocalypse. Bleach would be the best bet or better still would be some form of sodium hydroxide but both of those create a BIGGER respiratory issue once you get into sanding. Then there's mixing with other chemicals as you further finish the model... and then there's warping to consider. Can you tell I've sat awake at night trying to figure out how to move along? Really the best thing I could think of was to just take it all outside and bake in the sun for a week or so and see if the UV radiation would help kill anything. If I did that I'd have to spend the day babysitting the parts by rotating them for even exposure, unless I purchased some sort of motorize rotisserie. Mustang on a spit, that would be a nice YouTube video caption.
I just spent the morning going through this, any more updates after a year? LOL
