For this one I used Createx paints and mixed my three colors. Opaque Black, Opaque White, Opaque Sky Blue and Pearl Copper over a base of White Autoborne Sealer. I really like the Createx brand of paints as they are designed for Airbrush and work well. Careful when mixing colors as they usually dry darker than they look in the bottle.
If I did not have the Createx colors on hand I would use my favorite art store paint, Delta Creative Ceramcoat Acrylic Paint over a white base. These are a $1 for a 2oz bottle and mix well with distilled water and there are lots of colors. I have found that they do no rub off of the Flite Test foam board and can be sprayed or brushed. The finish will be flat, so if you want a gloss finish you will need to topcoat with their clear Ceramcoat Acrylic Varnish which works very well.
From their site:
The Delta Ceramcoat Varnish is a acrylic polymer that forms a tough, flexible, waterproof, ultraviolet-resistant film that is exceptionally clear and colorless. ... When dry, varnish may be wet or dry sanded. Soap and water clean up, non-toxic and low-odor.
