Wing Work
Hi Andre
Well, hopefully the wing will come out as per instructions.... As you can see, I used a larger sheet of foam board and traced the whole wing as I did the small Spit... Both halves... Hopefully, I won't have any problem with building this... You might also notice the slots for the wing braces has been modified... With the enlargement, of course the spars are bigger and on checking the original plan I found the mounting area to be just behind the first crease/bend... the original spots on the plan didnt match that so I modified so they would..... hope i'm right!
As for the fuse doubling, I figured on carrying this back roughly two inches past the TE of the wing, again, hopefully to add more strength to that area.... Found it cracked on the 42" spit...
So, on with tracing and then..................... get cutting..
Art.
The wing cord will be troublesome.
You'll have to make the wing with a few pieces of foam.
I cheated on mine
The motor mount/plate thing was so I could uses the shaft of the motor.
Wanted to run that nice spinner.
Wood was 1/2" dowels which I used to make the Tricopter.
Double up where you can.
My first crash it cracked right behind the wood structure where the double wall ended.
And you will want to carry that on beyond the wing section just to keep it all strong.
Cut away and have fun.
I did like the plane but she was beast to transport.
Andre.
Hi Andre
Art.
