Just heard your comments on the After Hours podcast, and I have a couple of comments:
- The Taranis stores your models in internal memory and has 60 model slots. You can if necessary save a model to the SD card and load another model from the SD card into the slot that was occupied by the saved model, but it's more work than simply selecting a model slot from the menu.
- Two of the switches on the Taranis are two-position: the momentary switch and the switch in the same position as the momentary on the other side. All others are three.
- With the internal module you can get 16 channels in two ways: binding two X8R receivers, one for the low channels and one for the high, or using a single X4R-SB, X6R or X8R receiver with SBus decoders, SBus servos or a flight controller board that supports SBus input. Using both the internal and external module you get up to 32 channels.
