I use the bare minimum when it comes to wiring on my Naze32. I should really connect a buzzer, but I can't find a good spot to put one so I just make sure my flights are around the 5 minute mark.
If you go with the quad ESC pack from RotorGeeks I would use the one ESC w/BEC on motor 4, and the remaining ESCs without the BEC for M1, M2, and M3. You don't have to wire it up this way, but I like having the ESC for M4 to have the BEC voltage so I can connect it to the M5 and M6 spot on my Naze for it to receive power/ground. Pop the connectors out form the plastic housing for the three ESCs without the BEC and put them all in one connector so they are in the correct order when plugged into the board. This will reduce the amount of connections you'll need to make and clean up the clutter as well. Here's a picture from my old quad. I don't like seeing wires, so this configuration works out great for me. Most frames also have a hole in the frame under the FC so it makes this connection quite convenient. All yellow wires are signal, red is power, brown is ground.
If you go the satellite receiver route you can also solder the 3 wires directly to the Naze32 and use a piece of double-sided tape to hold the receiver in place on top of the Naze. This would be the bare minimum for wiring you would need to get the quad in the air, and you won't need any additional cables other that the ones that already come on the ESCs or provided with the satellite receiver. I would assume the Orange Satellite receiver connects the same way, but I can't verify that as I haven't used one (the signal/power/ground wire locations may be different between the two).
If you plan to run a voltage buzzer you'll need two wires to supply battery power to the Naze32, and then two more to run wires to the buzzer if you mount it away from the board.
