Solved Aura 5 lite Board / Receiver issues
DavStr
OK - now we're getting somewhere. Just did a reboot of the transceiver and I now have throttle power. Wonderful. I'll go in to see if I can change it on the home screen to properly read throttle instead of Elevator.
DavStr
UPDATES: I walked away from the transceiver for a few hours, turned it back on and the throttle was now controlled by my elevator stick. I admit I'm totally new the the Open TX system but why would it change on me? I must be doing something wrong. Moving forward I'll post to an open TX forum to see if I can get any answers.
Are you running OpenTX or EdgeTX? Just curious. I'm still on OpenTX but have been contemplating migrating....
Bricks
I switched over to Edge TX basically everything is the same , having a hard time getting use to using touch screen as I still use the scroll wheel and buttons most. Touch screen is much faster when I use it. I did screw up my model import luckily i did not have a bunch of models on the TX16S if done properly at the right time it goes pretty seamless.
DavStr
UPDATES: I just realised that when I went in to the original model setup I was using an existing model. I dug around the Edge TX world and found a nice video on setting up a new model:
. After setting up a new model i was ab le to bind but .... still no stick control. I'll keep digging and will update when I solve the next challenge.
DavStr
All working now, binding was an issue until I changed the RF PROTOCOL from MULTI-DMS-X2F as per the Josh's Flite Test video recommendations for Radiomaster to Aura setup, to MULTI-DMS-AUTO. The final RF PROTOCOL ended up being MULTI-DMS-21F
Mr NCT
VP of SPAM killing
That was a long trip but you saw it through! As thorough as you were in documenting this it's going to help someone else. A pretty good tutorial from start to finish.
