DoctorKira
Glad you're up and flying
Have you updated the ROM yet?
The stock ROM for the kk2.1.x boards is garbage, and their port of 1.6 is just as bad. It's good enough to test the hardware, but I wouldn't trust it in flying. Look into flashing either the latest Steveis or RC911 ROMs. Not only will it improve the behavior, it'll make it fly much nicer . . . even more than getting opposing prop rotations.
Can I flash it using USBasp? Cause I flashed my esc's with it, can flash the board easily.
Also, does it flash same as the esc's? Like put a command line in cmd like
"avrdude -c usbasp -p m8 -U flash:w:bs_nfet.hex" (this is for esc)
and run it?
Edit: Nevermind, found it on google,gotta use kkmulticopter flash tool thingy. Which firmware version do you recommend? I have some experience in flying small multirotors in stabilize mode.
