Ordering tomorrow along with a few other things to include parts for the nut ball. They have to be here by the 15th.
Yes, Josh used tape and then hot glue in the build video but I have used just Blenderm tape for hinges, also.Silly question from a newbie.... how do you hinge the elevons?? Tape??
Thanks.
Thanks.
What battery are you using?Hi, build the F22 raptor (flite test model) very carefully as per the instructions.
But facing 2 problems while flying (rather trying to):
1. The plane always dives down towards the left side.
2. 1400KV motor not generating enough thrust. Tried 2200kv motor which also is not generating enough thrust. Prop is 8X4.5
Need guidance on how to fix these issues.
850mah 3S LipoWhat battery are you using?
Good find! TYCheck these:
Flite Test Firewall by MadSANMan
Here is a faithful reproduction of the Flite Test firewall used in many of their designs.www.thingiverse.com
Flite Test FT Elements Lightweight Firewall/Motor Mount by Kendalf
This is a motor mount I designed while trying to find a good balance between light weight and sufficient strength. My printed version weighs 5.4 grams yet resists any flexing from the motor thrust.This specific firewall is designed with 19x16mm M3 sized mounting holes, and the rectangular...www.thingiverse.com
Flite Test Build Parts by BobGarrett66
Here are a few parts for building your Flite Test RC airplanes. The pieces should be pretty identical to the originals. I'll have a few more up soon and will expand this summary.www.thingiverse.com
FT Elements Simple Firewall by beark54
This is the Flite Test firewall meant to be used with the FT Versa WingI printed this with .6 infill which makes it almost solid.you will also most likely need to seperate the pieces and rearrange them on the print plate.www.thingiverse.com
This will give you the fuselage all the way back to the motor mount. You can scale it up to fit the full size raptor as well. I've done both.Does anybody have a 3d printable motor mount for this F-22?
