Flyerminer
I've checked the prop direction, Calibrated the ESC's, even set the trim to the opposite direction. Nothing seems to help
. I'm using the Flite Test Electrohub build kit, using a standard X-configuration. I think its something wrong with the programming maybe but I'm unsure. I'm using a Multiwii Flip 1.5 control board.
The code used is in the link below:
Download of Code (zipped File)
I realize that is a lot to look at, but I really am in need of help. This quadcopter will not lift off unless I can correct this problem.
If it isn't a question of coding, this is a picture of the quadcopter itself:
http://i.imgur.com/eQzkf1l.jpg
http://i.imgur.com/ejsN46z.jpg
I'm using the following specs:
Electrohub Frame
Tiny Titan x2212 980kv motors
Lemonrx featherlight reciever
F-20A Fire Red ESC's with SimonK firmware
9x4.5mm props
Turnigy 2200 mAh 3S Lipo Battery
Please, anybody who can help, I really need it
Electrohub Frame
9x4.5mm props
