joh2239509
kk2.1 board
e-flite Park 300 1380kv motors
Turnigy Multistar 15amp ESCs
Spektrum dx6i transmitter and AR600 receiver
Anyrotor kit from the fabulous Flite Test guys
# Tricopter
-TGY375DMG Metal gear digital servo
-Props mounted using built in prop savers on motors and o rings
-Flips every time when launching. I've checked all settings, calibrated ESCs, calibrated kk2.1 board, balanced props and check correct rotation direction, and everything else imaginable.
-One motor seemed to speed up more than others but I believe I have the ECSs calibrated better.
-Last couple attempts I was able to launch copter but it oscillates badly
-Digital servo has now stopped working. Possibly after crash?
# Quadcopter
-Same setup just four motors and no servo of course
-Will launch into air but then oscillates badly to the point of flipping sometimes
-Mounted motors upside down and used prop mounts this time
1) Are the Multistar ESCs even able to be calibrated?
2) What are some good kk2.1 beginner settings?
3) Should I be using a plane profile or copter profile on my dx6i?
4) Prop saver vs solid prop mount?
5) I have DT750 motors and Turnigy Plush ESCs available, should I try these instead?
Thank you so much in advance for any advice. I am so excited to build these machines. The Flite Test guys are amazing and want to support them as much as possible.
I'm out here in Arizona with plenty or clear skies and warm flying weather!!
# Tricopter
# Quadcopter
