Hayduke27
I have just about finished building the FT Guinea Pig, which will be my first twin engine airplane. I am currently connecting all of the electronics, and was hoping somebody could line me out a little on whether or not I'm doing things correctly.
As I currently have things hooked up, I have both ESCs' power connections going to a power Y-extension which connects into the battery. I then have the other ESC leads each going to another Y-harness that goes to the throttle plug in the receiver. I am not running differential thrust on the engines. Do I have things connected correctly? I haven't fired things up to test it, I wanted to ask first.
Secondly, is my y-harness to the battery the way to go, or should I just have individual extensions coming from each ESC to its own battery? Obviously that seems to be the way to go if you want an extended flight time. Is there anything wrong with running both engines off of 1 battery?
Thanks for any advice!!!
