Hi,
I was looking for foam board big enough and light enough to make a
Viggen out of it. so which foam would you guys recommend me to use?
Thanks
-Boxy!
Where in Aus do you reside? I ask because I get my FB locally and NOT from officeworks as they are about twice the price available elsewhere.
5mm is about the correct thickness of material for use on FT designs and those other designs made from DTFB. I use sheets 32" x 40" for almost all of my builds!
I use Megawood Larson-Juhl foamboard which has an office in Mulgrave Vic and supplies the local picture framing businesses and Art supply shops. Currently I get my sheets for around $10 and I use white and black in 5mm and 3mm in white.
The type of foam I use is the white, acid free, type with the standard paper which actually has 2 laminated layers of foam. Much stronger, slightly heavier.
For most FT designs it gives a fantastic finish though where the FT or other design tends to be a little tail heavy you may need to remove some internal paper. I actually make and sell my own FB designs locally out of the above specified FB and I have trouble keeping up with the demand!
Have fun!
