I am working on a new design and I would like some help testing if anyone is interested.
UPDATE: First round of testers chosen. Check back here for updates.
Requirements:
- you live in the USA because I am paying postage. If you want to pay postage you can live anywhere
- you use motors with 16mm x 19mm bolt pattern
- you actually USE them AND provide me some feedback.
I will send three sets out next week to the people that want to try them. If you don't have time to test them then please don't ask for a sample. When I get the feedback I will send you a revised set to keep until I refine it to the point where all or most of the issues have been resolved.
Here are some shots of what I have so far...
The main components are laser cut Delrin (same as rotor bones mounts). They snap together and are held in place with the screws for the motor mount. It requires a 4mm shaft of some sort. I will supply a fiberglass one for testing. It also has some 1.4mm wire for the servo and a du-bro quick connector, both of which I will supply. I am not supplying the motors, the rest of the tricopter or the boom.
INCLUDED:
- one tail rotor motor mount (laser cut Delrin parts 5 per set)
- fiberglass rod for pivot
- metal wire for servo
- quick connector for servo arm
- metal collar for attaching to pivot
- free shipping (lower 48 USA only)
NOT INCLUDED:
- motor, servos, wooden boom, zip ties, glue for mounting finberglass rod, any electronics.
Some motors with 16mm x 19mm hole pattern.
HobbyKing AX-2810Q-750KV
Value Hobby MR2212-900KV
Let me know if anyone is interested?
thank you
-david
Requirements:
INCLUDED:
NOT INCLUDED:
thank you
-david
