Question - in addition to your dxf and pdf files, can you export obj files?
Asking as I could then import the 3D objects into Blender and quickly turn Phoenix models.
That was my fault. Apparently I didn't save it at 1:1 scale. I have removed the old PDF file and inserted the new one. This should work for you.I will include it here also.
EZ glider maiden went ok, but needed more nose weight and a little down trim on the horizontal. Gusty winds certainly didn’t help at all. SeaChuck faired worse. Couldn’t achieve powered flight. Too much nose weight caused an immediate nose in and dislodged the wing and snapped at the center dihedral. Hopefully next attempt will go better.
I bought the basic power pack and it arrived very quickly. I have been putting together a couple designs, and will test soon. Here are the DXF files if anyone wants to try them out. ( CG has not been verified yet.) I will post final pdf plans once I have confirmed they fly properly. This is pretty cool , can't wait to send these to my young grand kids.
EZ glider was a success!! The wind finally died down this evening. Just got an almost 10 min flight before the rain started. I was about to try the SeaChuck again, but the rain is picking up as the sun is going down.
