Guys,
Maidened my Old Crow MM yesterday. Things didn't go so well
. Looking for any ideas.
Basically my son was able to fly it for about 1:30, me only about 30. Winds were about 10mph, maybe a bit more with gusts. It was a handful to keep in the air. It seemed to launch fine. Seemed maybe a bit underpowered and very sensitive to giving it more throttle. Seemed to want to go straight up. I've got the F pack and a 850 3cell nano tech. I had 30% expo and maybe a bit more dual rates then the gauge for low rates would suggest. I honestly didn't have control of it enough to tell you any other tendencies. I also didn't get it up in the air high enough, certainly not two mistakes high. Started to porpoise on me and hit straight down.
Should be easily fixable. I've already rebuilt the power pod as the thrust angle was all but destroyed. Wing detached but I can easily glue that. All servos, etc. are still functioning just fine.
Here are some items from the build I questioned:
- My battery doesn't fit real well. I've got it stuffed in there vertically (see the picture) as opposed to horizontally, and I had to cut out a portion of the cover to fit it. Could having some weight higher, rather than lower make any difference. I checked my CG pretty well with a jig and pencils and the plane inverted. I'd say it was pretty good, a little on the nose heavy side but could maybe have been more.
- I had to add 3 quarters to the front to get the CG right. I put them in a cutout in the cover, again the weight was higher then the wing.
- I'm running an APC 6x4 prop.
- I don't believe I have any down thrust angle when my pod is mounted.
I'll get it fixed and try it again. I had hoped this would fly similar to the big mustang and handle the wind in a similar fashion. Need to figure out how to get it tamed so I don't have repeat.
Here's a link to my son's semi successful flight. Don't know of someone can see anything that might be wrong in this.
https://youtu.be/fZ8LaRZgBsA
