You are getting some longer flights, and it seems like you are consistently making the correct control inputs. As always, some observations from the video:
There is something off about the behavior of your airplane. It climbs too steeply when thrown and stalls right away. Double check the following things very carefully:
-That the CG with the battery in (ready to fly) is correct, and set up to give you a slight nose heavy setting.
-That your elevator, when in the neutral position, is exactly straight, and not angled upwards, and similarly that your elevator trim is centered. Check this with the battery in and the controller powered on.
-That you have some downward thrust angle included in your power pod. This is most easily done by adding a small spacer between the motor and firewall at the topmost mounting screw. If you have any leftover motor shaft adapters (they come with the props usually) they make good spacers. Down thrust is necessary to balance out your high lift airfoil.
As you said, it looks very windy. I can see trees in the background swaying, and your friend's shirt is flapping in the wind. You may have better luck flying in calmer conditions. That being said, if you do choose to fly in strong winds with a slow flier like the TT, may I suggest that you keep the plane flying into the wind as much as possible. Try a shallower launch angle, more towards the horizon, and less up. With as much wind as you have blowing, the plane will easily catch enough air to fly, and if you throw it at a shallower angle, it wont pitch up as much. Once you have your hands on the sticks, do your best to keep it pointed into the wind, and try not to let it turn and blow away from you.
You are doing well, I can see definite improvement since your first few videos. As always, I'm looking forward to seeing your next practice session.
