How do I re/calibrate it? Is that the throttle fiddling that I did when I first plugged it in?
or do you mean the bl_heli firmware flasher thing? (this esc is definitely not fancy enough to interface with that app.)
I replaced the ESC and motor for a ~B pack equivalent and a 30 amp esc. It's got almost a 1:1 PWR but I had to increase the size of the empennage and it flew like it was tail heavy no matter how forward I moved the battery [CG was almost on the leading edge (
Video will be posted eventually...
I have a hunch that the CG issue has more to do with the wing "shape" rather than the actual tail weight. I think it kinda looked like a nutball: super high alpha, really "rolley", weirdly fast looking.
Gonna have to rebuild the fuselage and figure out landing gear before I can fly it again.
Side note: I had an idea for a pusher prop with a "suspended" power pod. Doodle below.
The concept would not be an aerobatic model, obviously.
