Might Mini Corsair Too heavy?
Flqk
Recently made a mighty mini corsair. It weighs in at 1 lb. I built it out of the foam from the kit. On my maiden flight, it kind of vertically wiggled for a second then nose dived. Should I get a bigger motor or try to lose weight? Any help would be appreciated.
Specs:
2200kv motor
30a esc
850mAh 11.1V 45C 3S1P battery
6ch. reciever
4 x 9 g servos
....Any help would be appreciated.....
Is the prop on the correct way? The numbers should face the direction of travel.
If backwards, the numbers facing where the plane has been, you will only get half as much thrust as you should.
Flqk
Yes, it was the right way. The motor was an old one from a couple years ago, so Imma get a new one and try it.
