Thank you! These pictures are SO helpful- I don't have Fusion 360 to access the internal structure, so I was just using trial and error (and a lot of blue painters tape) to fit everything together.
Doesn't that go between the cockpit bottom and cockpit base? Once you fold it, you'll see it fits around the rectangle cutout on those two pieces. I think you can also see it on one of the internal framework pictures posted earlier.
Nice job! The nacelle boxes are in the wrong place, I'll post some pictures to show how it's done.
Make sure to glue the firewall directly onto the nacelle boxes, they aren't designed for a powerpod. I'm also going to design a firewall for this plane like the ones on the new mighty minis. That should be coming shortly.
For the front spar, it goes on the outside, but only if you're using 3/32nd of an inch thick plywood. If you use anything else, the wing won't fit. For the back spar, it doesn't really matter.
There's no hole in the top wing skins for all the wires coming from the nacelles and servos to enter/exit. Or is there and I'm just blind?I know there is one in the front of the wing but there needs to be one in between the nacelles.
Yes you're supposed to. That's just hard to account for in cad, and it would mess up the unwrapping algorithm, so that's why it's open in all the pictures.
