nnKi-61
nerdnic
nerdnic.com
DETAILS
Hi friends.
​The Japanese fleet has always fascinated me and I'm excited to finally bring one to you all! In form with my previous designs, I chose a subject that is less represented in the model community as a whole and specifically in the DTF area. So please, enjoy this plane and share your build here in this thread!
If you like this design then perhaps you’ll like some of my others as well.
SPECS
WINGSPAN​
40in
FUSE​
27.2in
CHANNELS​
4-6
WEIGHT​
Airframe - 300g
ELECTRONICS​
Basic - Power Pack C
MOTOR - Turnigy D3530/14 1100kv
PROP - 9x6 APC
ESC - Dynam 30a
BATTERY - 2200mah 3S
SERVOS - 4x 9g
Speed
MOTOR - Tacon Big Foot 10 1100kv 1100w or NTM 3548 1100kv
PROP - 10x10 APC
ESC - 80a Dynam
SERVOS - 4x 12g metal gear
BATTERY
120 MPH - Heavy Duty 3300 4S
85 MPH - Zippy 2200 3s 40c
BUILD DIFFICULTY​
Beginner – You’ve never flown a plane before, let alone done a scratch build
Novice – You’ve flown a plane but have no experience with scratch building
Intermediate – You’ve flown and built a few FT style planes before
Advanced – You’ve mastered the standard FT build style and are looking for a new challenge
Expert – You’ve mastered all build techniques and aren't afraid to improvise or tackle tedious builds
This is a intermediate to advanced build.
PILOT SKILL​
Intermediate
MATERIALS​
8 Plastic BBQ reinforcements
7 Control rods
7 Control horns
4 12" BBQ Skewers
3 Coffee straws
3 DTFB (20"x30")
1 Poster board
1 Clear plastic overhead transparency (OPTIONAL)
1 Firewall
1 Aluminum 1/16" x 1/2" x 24"
​or
1 Basswood 1/8" x 3 x 24"
PLANS
nnKi-61 Plans
FAQ
Is this a swappable?
It will accept a FT power pod as well as a new pod I have designed. The new pod is larger to accommodate a bigger battery.
Is this a good plane for a beginner to fly?
No. It's a bit too advanced for a beginner.
How do I know if I should use aluminum or basswood?
200-500w = basswood
500+ = aluminum
Are flaps required?
No, but they do help! If you're going for a heavier/faster setup, I would suggest adding them.
There is a plane I want you to design, what’s the best way to suggest it to you?
Please use the request form here on my site.
PICTURES
Thanks for checking out the nnKi-61! If you built one of my planes and enjoyed it please consider donating a few bucks so I can buy more supplies to make more great planes.
Jugsy
I'm going to go on record here and say that I'm interested in any design you think of :p I like seeing some of the "less famous" warbirds in RC!
nerdnic
nerdnic.com
Some more details
Wing span is 1000mm, basic fowler flaps, 4-6 channel, runs off a 2200 3s up to 3300 4s.
Plans will be free and I'll have a build video to accompany.
View of the underside:
Canopy/hatch is 100% scratch and easy to build:
slyke
Nick,
That canopy looks great. Now that you have added more designs to your list I wondered which have the best flight characteristics?
-Stephen
nerdnic
nerdnic.com
The nnChipmunk v2 is my favorite so far in terms of feel. John is a big fan of the 61 though, I haven't flown it yet but will soon!
nerdnic
nerdnic.com
Just right. I've started to play more with wing attack angle to correct the need for down thrust. So from the nnChipmunk v2 moving forward all my designs will not require down thrust.
Jaxx
I'm trying to see if I can program the transmitter to eliminate the need for both. I like when the spinner fits flush against the nose of the aircraft.
AircPirateNinsei
Foam Board and Filament Shugenja
:applause: It's an awesome plane and I'm looking forward to the plans! ;)
There are a lot of paint schemes available for the Tony!
The decision will not be easy! :confused:
