I have Turnigy Multistar esc's. 2-30amp ones and 1-15amp one.
a kk2 board.
batbone frame
I kept flipping on what I wanted to be my maiden flight. I can't even get it to hover. I Hexa checked that props and motor rotation were correct. I thought I calibrated the esc's because i heard the beeping sounds when following the button 1 and 4 procedure. Then I had read that you can't calibrate the multistars. Had the KK2 board mounted in it's foam box it came in. I thought maybe the wires that I had stuffed in the batbone were pushing up on the bottom of it so i pulled the wires out so nothing would be pushing up on the bottom and hot glued the bottom of the foam box flat to the batbone and hot glued the kk2 to the foam. I know it is facing the correct way because of the arrow on the bottom of the board points to forward. When building I had a screw stick to the magnets of the front right motor. I heard the spark and unplugged battery. I found I had fried two esc's but the motors tested fine when hooked to the still good 15 amp speed control. Is it ok to have different amp esc's? Any suggestions on what I should do next to get to a hover?
a kk2 board.
batbone frame
