Assuming you’re taking off from the ground (rolling takeoff), check how much deflection you have in your elevator. You may have too much throw and when you think you‘re giving it just a little, you’re giving it quite a bit.
A buddy had this happen on his Corsair. Dialed the throw back to 70% and all is good.
If you’re hand launching, does the airplane pitch up THEN dive into the ground? If so, it’s again, too much deflection or a tail heavy cg, resulting in a stall. If it just goes down right after tossing, check the incidence of the wings and of the horizontal stab. If the horizontal stab is angled down, it could be forcing the airplane up a bit. Then, you add elevator and over she goes. It’s unlikely, as it’s happening with two different airplanes.
