daniZZ
Assuming you’re taking off from the ground (rolling takeoff), check how much deflection you have in your elevator. You may have too much throw and when you think you‘re giving it just a little, you’re giving it quite a bit.
A buddy had this happen on his Corsair. Dialed the throw back to 70% and all is good.
In the first maiden I had a simple radio without settable dual rate values. I was using the preset low rates but for the second try I already got my flysky FST6 and cut out a throw gauge from the FT Mustang plans and set up the throws accordingly.
[QUOTE="
If you’re hand launching, does the airplane pitch up THEN dive into the ground? If so, it’s again, too much deflection or a tail heavy cg, resulting in a stall. If it just goes down right after tossing, check the incidence of the wings and of the horizontal stab. If the horizontal stab is angled down, it could be forcing the airplane up a bit. Then, you add elevator and over she goes. It’s unlikely, as it’s happening with two different airplanes.[/QUOTE]
Exactly that happened on the second attempt. It was going up in rocket like position and after releasing the elevator it was coming down in a rock like manner.. But how I already sad, I had the deflections dialed in according to the Mustang throw gauge.
By the way it was the same plane just repaired after the first "Flite test" failed.....
That means I should move the Cg more forward?????
